Re: 340 hydraulic valve problem
Posted by rumplestiltskin on May 01, 2009 at 06:38:25 from (192.88.212.34):
In Reply to: 340 hydraulic valve problem posted by tesmith66 on April 30, 2009 at 04:46:17:
I didn’t see that exact symptom in the troubleshooting section of the manual. This is the closest thing:
Condition: Control valve cannot be readily moved from neutral.
Causes/Remedies:
1 – Control valve gang retaining bolts (i.e., valve mounting bolts) and stud-nuts too tight, pinching valves in valve bodies. / Loosen retaining nuts and bolts. Re-torque to 25 ft-lbs.
2 – Control valve linkage binding. / Check and free up all hand levers and linkage.
3 – Orifice in upper unlatching piston plugged. / Dismantle control valve, clean thoroughly, renew gaskets and seals.
4 – Control valve and body scored. / Replace old valve with new. Check system for dirt, abuse or cause of failure.
I hope this helps (my money’s on #1 above).
Mark W. in MI
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
