Re: 3588 can't set low idle and still shut down tractor
Posted by pete 23 on May 01, 2009 at 06:59:25 from (173.87.1.12):
In Reply to: 3588 can't set low idle and still shut down tractor posted by Joel_M on April 29, 2009 at 13:20:52:
Spring is very easy to take out, merely hold capsule so it cannot turn (maybe using a vise grip very carefully if necessary) and use a large screwdriver to take plug out of end. So far as the operation of innards, well, you are in essence only moving the control sleeve on the plunger through governor linkage inside, at shut off you are moving sleeve far enough so port is exposed to the point where plunger can no longer build enough pressure to open the injection nozzles so there fore it quits running.
