The use of 4 field magnets produces more torque (and consumes a bit more amps) than a 2 pole. My concern is that there may be armature differences between the two setups. The armature pole to commutator segment offset. determines which winding gets what polarity when. As does the location of the brushes around the commutator. I would check the commutator carefully to assure the same offset configuration, and number of segments etc. One simple way to do this is to silver solder a copper stud to the top of the switch post on the starter body without the post. Crossing the field connection wires where they attach to the brushes (to the opposite brush should make it reverse, but it might not be in ideal time. Thus will run, but not optimally. Another option is to have a threaded stud put in to replace the switch post at a shop. No issue, broken stude are commonly replaced. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
