Re: Tire Service: $432.50
Posted by glennster on May 01, 2009 at 10:11:07 from (99.135.95.42):
In Reply to: Re: Tire Service: $432.50 posted by Andy Martin on April 30, 2009 at 15:07:05:
yup, just like that, works pretty good, get the jack all the way down, the hook the chain tight. i keep a spray bottle of soapy water handy and when you start to push the bead down, squirt some in there, helps to loosen it up. most times the bead will drop without re-positioning the jack. pretty easy, just be careful the jack doesnt slip. another trick a fellow yt-er shared with me for an old tire stuck on a rusty rim, lay the tire flat on the ground, and pour about 1/2 cup of gasoline around the bead area and let it set for a day. dont light the gas!!! let it evaporate off. it will soften the rubber and let the bead break easy on a junk tire.
