Posted by Bill Jones on May 01, 2009 at 10:46:30 from (74.244.174.56):
Have a friend who wants to put a starter on a F20, which does not have a Bell Housing hole. He has a double pulley on crank shaft, but what kind of motor starter does he need to mount on the frame.He can charge the battery with a battery charger as often as he will use it, so no generator is needed. Thanks
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
