If you mean AMMETER, any ammeter that fits the hole will work. (Ammeters are insensitive to both voltage and ground polarity).
Tip: Get one one with a scale reading of 20-0-20 or 30-0-30. Ammeters with larger max readings will deflect so little on a stock 6 volt tractor system as to be pretty much useless.
Regarding voltmeters I'm uncertain whether "6 volt" voltmeters even exist. (In my 40+ years of fooling with old tractors and trucks I have yet to see one...)
And keep in mind a 12 volt voltmeter will NOT work on 6 volts because the the voltmeter's low scale stop usually corresponds to 8 or 9 volts. Means that on a 6 volt system charging normally (7.5 volts) the hand on 12 volt voltmeter won't even budge off the pin.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
