Re: Generator Belt Replacement on Farmall Super M
Posted by old on May 01, 2009 at 21:36:47 from (4.244.186.238):
In Reply to: Generator Belt Replacement on Farmall Super M posted by Melvin Ware on May 01, 2009 at 21:29:44:
Water pump pulley has a lock screw on it. You loosen that screw then tap the outer part of the hub to loosen up the pulley. You tighten those belts by making the pump pulley narrower and that in turn tighten up the belt. A good spraying of PB will help a lot also
