Re: farmall m 12volt at points
Posted by Dave S. on May 02, 2009 at 06:35:00 from (208.92.169.183):
In Reply to: farmall m 12volt at points posted by jeremy fuler on May 02, 2009 at 06:10:58:
If you get a 12 volt coil make sure it has the resistance built in, it should say on the coil.
Some coils are marked 12 volt but still need a external resistor.
