Simply get a true 12 Volt coil. (12 Volts no external resistor required) NAPA IC14SB is a common choice. Install it and remove the resistor. If your system is positive ground the + terminal of coil goes to distributor. If the system is negative ground the - terminal of the coil goes to distributor. The points don't care if they are in a 6 volt or 12 volt system.
Voltage seen at the coil depends on whether points are open or closed. Here's a link to a chart that may help explain that.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
