Re: Super M wiring
Posted by John T on May 02, 2009 at 11:59:43 from (66.244.97.31):
In Reply to: Super M wiring posted by Ludwig on May 02, 2009 at 10:20:19:
On that 6 volt system, I would use:
00 Gauge Battery n Starter n Ground Cables
IF you wanna just buy ONE ROLL OF WIRE
12 Gauge stranded copper with crimped n soldered terminals would work, maybe get a roll of red and another of black etc.
Id use 12 for the charging circuits and ignition and maybe 14 on the lights if you wanna buy two different wire sizes. Of course, you could also get buy with 14 gauge for everything but I believe in a bit of overkill and slight oversize to reduce voltage drop which is why Id use more of the 12 gauge even if 14 or 16 will work.
Or see Jim in New York at Agri Services www.wiringharnesses.com and buy a new wiring harness
John T
