Posted by makin,hay on May 02, 2009 at 14:16:19 from (69.95.141.177):
After 2 weekends of messing around with the press. plate and disc, I measured the inside of the pilot bearing on the flywheel. If you look at it it looks like the right one and I did stick my finger in it last weekend to check if it was tight. . It turns out it is not the right one. I pulled the bearing out and checked it on the shaft and it was VERY sloppy so the shaft must have just been wobbling around in there which explains alot. No one around here has one in stock so now I wait till Tuesday night. It was an expensive screw-up on who-ever installed it as it bent my new clutch disc. Dont know why I did not check that before, never thought it could be wrong. As I said last weekend, at least I am learning alot. Thanks to all who helped
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
