Re: Generator Belt Replacement on Farmall Super M
Posted by glennster on May 02, 2009 at 18:37:17 from (24.14.63.246):
In Reply to: Generator Belt Replacement on Farmall Super M posted by Melvin Ware on May 01, 2009 at 21:29:44:
pb is pb blaster,available at any auto parts store. its a real good rust penetrating oil for the money. spray the threads on the hub up real good. if you have never done one before, completely remove the locking bolt. should be a square head bolt with a jam nut on it. the threads on the hub are separated with spaces, when the belt is tight enough, the stop bolt holds the hub on one of the spaces. opposite 189 degrees around the hub is a raised hump. you can get in there with a brass drift or steel rod to help tap the hub loose. may need a little heat if its stuck, but dont nuke it!!! here is a pic of the hub and my brass drift for loosening them.
third party image
after you get it loose and the belt off, brush some anti seize on the threads so it comes off easier next time!!!
