Re: 656 doesn't want to split (pics)
Posted by Owen Aaland on March 11, 2009 at 19:58:05 from (65.165.246.54):
In Reply to: 656 doesn't want to split (pics) posted by TX656 on March 11, 2009 at 17:32:43:
The IH stands for splitting these tractors have a "L" shaped bolt to hold the top of the stand to the frame. The unthreaded end of the bolt goes through the bolt hole just above the flat part of the frame to support the back plate as the tractor is split.
The easiest way to do it is like the Tractor Vet says, just unscrew the frame bolts but leave them in the holes. As you start to split it just push them back in again. You're going to want them there anyway when you reassemble it.
