Posted by screwstick on May 02, 2009 at 19:26:51 from (70.168.221.40):
In Reply to: Cub timing posted by Chuck Nalley on May 02, 2009 at 10:28:03:
Hard to see the mark with the governor seal in there. With the #1 piston at TDC and the timing pointer lined up the the mark on the crank pulley, the timing mark on the idler gear will be in view, looking through the hole where the distributor mounts up. Of course with the seal in there, the dot can't be seen, so you need to come in through the front with a insp mirror, locate the dot and mark the teeth with a piece of chaulk. Then the governor can be reinstalled in time. The recesses on the gov gear for the distributor lugs should be at roughly the 2 and 8 oclock positions.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
