Posted by Old-F20 on May 02, 2009 at 23:26:49 from (71.7.98.117):
In Reply to: F-20 Flywheel posted by SSF-20 on May 02, 2009 at 19:43:28:
dont make a puller that bolts to the bellhousing, you'll damage things. first off, it will put a tremendous lateral load on your main bearings, which they are not meant to handle. secondly, cast iron is strong, but it wont withstand those large lateral loads either. the correst way to put one on is to actually have a picec of roundstock threaded to go on the rear of the crank. the end of this tool should be threaded so you can make the 'cage' that bolts down to the flywheel be able to go through it and tighten it down. makes sure you have your dowel pin lined up correctly, or you'll be taking it off again.
im probably sure im not describing it right, if so i can take some pics of the tools ive made.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
