Re: how to time a 826 with 358 german motor
Posted by Hugh MacKay on May 03, 2009 at 02:18:33 from (216.208.58.158):
In Reply to: how to time a 826 with 358 german motor posted by Jim Starr on May 02, 2009 at 17:57:07:
Jim: One other matter on timing advance on a diesel, turn the engine the same rotation as operating when bringing it up to timing marks. there is enough looseness in the gears to put it off several degrees if you turn the engine backwards to the desired mark.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
