Re: Cub timing
Posted by James Rumph on May 03, 2009 at 05:26:47 from (24.192.125.175):
In Reply to: Cub timing posted by Chuck Nalley on May 02, 2009 at 10:28:03:
Get ahold of a digital read out timing light that has a rpm reading [tach].
Run the motor up to full throttle and turn the dist tell yo get the max rpm on the tach and lock it down.
I have a dyno and we set the bigger tractors timing under load . But setting it the way i listed above will get you ware you want to be.
Remember your only useing the tach in the timing lite nothing else, it lets you stand right there to see the change.
