Re: No 1 plug mis-fires when warm? on a 140?
Posted by Clean John on May 03, 2009 at 11:01:24 from (216.228.193.227):
In Reply to: Re: No 1 plug mis-fires when warm? on a 140? posted by NawlensGator on May 03, 2009 at 07:20:46:
Hi Again --yes the co2 will bring the temp down to very cold if appied for very long--Also here's another thought -why not swap the other tractors module if its working ok? Might be easier to swap dist if your up to the timing chore. just a thought! John
