Posted by Old-F20 on May 03, 2009 at 12:20:49 from (71.7.98.117):
In Reply to: F-20 Flywheel posted by f20inmi on May 03, 2009 at 05:49:30:
f20inmi said: (quoted from post at 05:49:30 05/03/09) There is another way which could save you from having to fabricate tooling. The bearings folks will tell you that impact loading and bearings don't mix real well. Basically, little indents (brinnelling for those who might be looking to add the technical term to their vocab) left in the race ways will utlimately result in problems later on.
I talked to a fella who pulls and replaces flywheels on F series frequently. He said that he has had good success by taking advantage of thermal expansion. You can set your flywheel on the bbq grill for about half an hour until it's ~300 F. An infrared thermometer works well to gage the temp. Screw a couple bolts in threaded holes to help you handle the flywheel and pin. It doesn't hurt to put the dowel pin in the freezer for a couple hours. Of course, welders gloves are a "must have" to handle the hot flywheel.
You can slide the flywheel on the room temp crank shaft while another slides the pin home. After it was in position you can run the nut down while the flywheel is still hot to get in home position. Took a couple helpers to make it happen; but made a pretty tough job which could have taken minutes happen in less than 30 seconds.
Of course I have the utmost respect for Old-F20 and Cowmans' advice and am sure that they have had good success with their procedures.
I would be interested in seeing your puller. Was it fabricated or a commercial model? Would you be able to post a picture?
Good luck.
what does 300 degrees do to a felt oil seal????????
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
