Re: No 1 plug mis-fires when warm? on a 140?
Posted by NawlensGator on May 03, 2009 at 12:34:55 from (68.155.73.155):
In Reply to: Re: No 1 plug mis-fires when warm? on a 140? posted by Bob on May 03, 2009 at 08:04:26:
Thanks for all the good suggestions. They're much appreciated.
Compared both elec ignitions. Air gap on sputter'n one is noticeably larger. I could only tighten to a gap of about 0.08 inches, but still less than before. Still more than the other. I'll run it and see if it's better (rain permitting).
There is wobble in the dist shaft. In/out about 1/8th inch, side to side not so much, rotation a few degrees (5 or less). How does one replace the bushing? Is this a big job? Can you loosen and pull the shaft out, replace, and reinsert?
I thought about valve adjustment but that shouldn't shouldn't cause spark loss.
Before I try swapping modules I'd probably just get a new one.
