Re: No serial #???
Posted by Mark Peters on May 03, 2009 at 14:44:45 from (66.222.7.31):
In Reply to: No serial #??? posted by Darald in Sk on May 03, 2009 at 12:18:00:
One other simple thing thats different between a 2oo and a Super C if thats all you`re trying to determine is location of the serial # tag. I realize you said it`s missing, but the 4 rivets or 4 holes from the rivets would still be there. The serial # tag on a Super C is on the right side of the tool box thats under the seat and the 200(and 230, for that matter) has the serial # tag on the left side of the clutch bell housing right above the 1 1/2" hole where you grease the throw out bearing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
