Re: International 56 Corn Planter??????
Posted by formerly ny bill on May 03, 2009 at 17:41:32 from (66.24.241.175):
In Reply to: International 56 Corn Planter?????? posted by westernpafarmer on May 03, 2009 at 15:07:17:
to slow down the speed, you would want a smaller sprocket on the driver, and/or a bigger sprocket on the driven side.
the speed should be independent of the seed size. the plates need to match seed size for the correct seed placing. 1 seed per notch (loose but not enough room for a second seed to try and wiggle in here and there).
i don't have a manual for your planter, but a crude way to check population would be to run it in the driveway and play with sprocket combinations to get 1 seed every 5-7".
hth
