Re: TA adjustment on my 1486
Posted by pete 23 on May 03, 2009 at 18:19:11 from (173.87.1.12):
In Reply to: TA adjustment on my 1486 posted by Larry B 1486 on May 03, 2009 at 12:15:03:
I am with Ben on this one. I have seen so many pto shafts pushed back, bending the large washer and unfortunately this doesn't always show up immediately but it can. Usually causes seal leakage but it can mess up clutch backing plate and or disc. I guess I never saw one push ta drive shaft back but it sure could. You have an issue with the dealer for sure.
