Re: 300 Utility - torque amplifier v.s. independent PTO
Posted by D Slater on May 03, 2009 at 18:58:16 from (71.182.28.43):
In Reply to: 300 Utility - torque amplifier v.s. independent PTO posted by tractorsam on May 03, 2009 at 07:35:44:
Needed, shaft- clutch plate to T/A, Shaft and gear-pto drive, pto driven gear, Splinded coupling or pto disconnect parts, pto shaft that passes through trans counter shaft, Housing and bushing for rear of previous shaft, exstention shaft with 2 couplings, pto unit. pressure plate with splines, may have them already. Bunch of work.
