Re: Rusty gas tank (inside tank rust)
Posted by billde on May 03, 2009 at 20:27:46 from (72.26.89.156):
In Reply to: Rusty gas tank (inside tank rust) posted by Doversix on May 03, 2009 at 19:08:07:
Doversix said: (quoted from post at 19:08:07 05/03/09) What is the best way to clean the inside of this gas tank?
muriatic acid, flush with water, pour in a couple gallons of E 85 to absorb any remaining moisture. I don't use sealer unless there is a leak.
