Posted by Owen Aaland on May 04, 2009 at 00:46:47 from (65.165.246.54):
In Reply to: 806 fuel in oil posted by ChrisLSD on May 03, 2009 at 18:23:58:
Most likely the same problem as your 560 but with the 806 the seals are a little different. Instead of the two seals on the shaft that slide into the injection pump, the 806 has two conventional type oil seals in the adapter housing between the pump and the engine. It is a little more difficult to repair because the pump drive shaft has to come out so you have to remove it from the drive gear.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
