Re: water in fly wheel
Posted by gene bender on May 04, 2009 at 03:48:33 from (67.55.227.59):
In Reply to: water in fly wheel posted by graygoat on May 04, 2009 at 03:39:36:
You will have to split the tractor as the frost plug is leaking after you get the tractor split you will see the plug. After removing the plug now would be a god time to remove the lower outlet going to the radiator and flushing the lower part of the block ans there is without a doubt lots of crud in that passage. There are some small nickel sized holes that let the coolant by the sleeves down to the lower part of the block and they can get plugged over the yrs. You will be able to clean out the passages with high pressure water and compressed air.
