Re: Farmall M radiator
Posted by GordoSD on May 04, 2009 at 09:06:42 from (66.115.200.140):
In Reply to: Re: Farmall M radiator posted by Andre (NE) on May 04, 2009 at 06:08:11:
Describe :somewhat loose" How much deflection in the middle between pulleys? You have to turn the water pump also, not just the fan. No more than 1/2 inch of deflection with moderate force.
Gordo
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
