Re: LOUD squeal while stall-testing the clutch on an H
Posted by Bob M on May 04, 2009 at 12:32:09 from (151.190.254.108):
In Reply to: LOUD squeal while stall-testing the clutch on an H posted by amnion on May 04, 2009 at 12:00:12:
First off the clutch and brake test are best done in 5th gear. Even with decent brakes it's tough to hold an H back in 2nd. And it's much easier to slip a marginal clutch in 5th than in the lower gears.
That issue aside, smoky exhaust could be a couple things: 1 - A tired, oil-burning motor that smokes under load, or 2 - A healthy engine that just hasn't seen a load in a while.
If it's #2 it the exhaust will gradually clear after running 5 - 10+ minutes wide open - quicker if you can get a good load on it.
#1 however will just keep smoking - it may even smoke worse as the engine warms up.
Squealing could be from the brakes, a rusty clutch plate or a severely worn out clutch. Hold the tractor stationary in 5th gear (block the rear wheels or run the front end against a tree) and gradually let out the clutch. You'll know quick whether it's the clutch or the brakes!
