Re: LOUD squeal while stall-testing the clutch on an H
Posted by mkirsch on May 05, 2009 at 05:11:41 from (64.80.108.55):
In Reply to: LOUD squeal while stall-testing the clutch on an H posted by amnion on May 04, 2009 at 12:00:12:
Another good clue would be WHERE the "squeal" was coming from on the tractor. You can easily tell if the squeal was coming from one side or the other, the front of the tractor, the rear of the tractor, down by the brakes, from under the gas tank.
Band brakes are often noisy. Maybe that was it. Try the test again and listen carefully to the noise this time.
...and when you said the tractor "barely" moved...
Did the engine lug down, or did it keep roaring away? If it lugged down, the clutch is fine. If it didn't then the clutch is slipping.
