Re: Farmall front rockshaft arm/lift link hook-up
Posted by Scott A. Johnson on May 05, 2009 at 10:41:40 from (75.44.52.165):
In Reply to: Re: Farmall front rockshaft arm/lift link hook-up posted by Rootsy on May 05, 2009 at 09:22:30:
Thanks for the reply and picture. That clears it up. I took a rockshaft pin from the right side and thought I could use it on the left, but it is clearly different than what should be used. My book shows IH #350142R1 for the pin. That pin has a larger head and does not use a cotter pin which I see is the one I need to get from the dealer. Thanks again on your help
