Well i am guessing here as myself i have never worked on a 464 but i am betting that it has the standard steering motor And to fix it you will need a 1 1/8 socket a steering wheel puller two 5 1/2 inch grade 8 1/4 x 28 bolts a 1/4 28 tap to clean out the puller holes in the steering wheel a pair of snap ring pliers a dental pick and about twenty min. of your time for the first one.Ya remove the nut that holds the wheel on have the puller holes cleaned out install the puller and tighten down tight then give the puller a rap and the wheel will come off Now remove the puller from the steering wheel remove the snap ring and set the steering wheel back on the shatf and give a real hard turn either way is fine , by doing this it should pop the seal out and just reverse the prosess.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
