Re: Gear Reduction Starter Needed
Posted by Allan In NE on May 05, 2009 at 17:28:32 from (148.78.100.118):
In Reply to: Gear Reduction Starter Needed posted by M Miller on May 05, 2009 at 09:41:12:
Yep, like the other guys say.
You are setting yourself up for a disappointment. Ya want a diesel engine to spin faster, not slower so as to develop the heat for ignition.
If it is a hard starter, maybe it is a little weak in the wind department?
Allan
