Re: CUB SPARKS !!!!
Posted by wayne in mn on May 06, 2009 at 05:35:01 from (68.119.24.230):
In Reply to: CUB SPARKS !!!! posted by JIFAN on May 05, 2009 at 20:14:03:
Where is the ground cable for the battery fastened? When starting the battery could attempt to create a ground path through any other metal that runs from the engine to the framework if the ground connection or cable is not in decent condition.
Run a good ground from the engine directly to the battery and see if your sparks go away!
