Re: CUB SPARKS !!!!
Posted by Bob M on May 06, 2009 at 05:57:22 from (151.190.254.108):
In Reply to: CUB SPARKS !!!! posted by JIFAN on May 05, 2009 at 20:14:03:
Had that happen once on a Super M.
Problem turned out to be a bad ground (fresh paint) between the starter and the flywheel housing. Instead of grounding thru the starter mounting flange, return current flowed from the starter housing to the switch enclosure then up the pull rod and grounded to pull rod bracket on the steering post.
Before you start buying parts do as Wayne suggests: Run a jumper cable between the grounded battery post and the starter house and see if the sparking disappears.
