Re: Gear Reduction Starter Needed
Posted by M Miller on May 06, 2009 at 10:54:39 from (76.250.116.2):
In Reply to: Re: Gear Reduction Starter Needed posted by mkirsch on May 06, 2009 at 09:38:15:
I have tried numerous 12 volt auto batteries. Then I install the battery that is listed for this tractor. It is (1) 12 volt. I installed that & new cables. The cable I used was welder cable. I can"t remember the size but it is 5/8" in diameter which was larger than the existing cable. This battery lasted approx 8 months. The charging system is working. I have replace the generator with an alternator. I have not chked the glow plugs of late but when chked eariler they were working. When using the glow plugs I leave them heat until the indicator disk is a cherry red. I have since changed to (2) 900 CCA 6 volt batteries. This setup has lasted the longest. But I would like to get back to the orig. size battery
