Re: IH 3121 backhoe
Posted by Joe L on May 06, 2009 at 16:25:31 from (72.74.217.200):
In Reply to: Re: IH 3121 backhoe posted by jdemaris on May 06, 2009 at 12:31:56:
Thanks, I also noticed the slop between those two parts. I also noticed the shaft has dropped down a little bit, should a shim (load washer) be added to the bottom to bring that up a bit? I'll search for a new part. Do you know why the hydraulic line passes thru the center of that shaft?
