Re: oiling hub bearing on fan on Cub
Posted by screwstick on May 06, 2009 at 19:08:16 from (75.89.26.231):
In Reply to: oiling hub bearing on fan on Cub posted by Farmallb on May 06, 2009 at 18:27:42:
The screw can be accessed from the side without having to remove anything if you have an oiler with a long spout or a syringe with a flexible tube on it.. Have some rags or a small container ready to catch the extra oil that will spill out when you rotate the hub.
