Re: cub farmall ?????
Posted by screwstick on May 06, 2009 at 19:35:00 from (75.89.26.231):
In Reply to: cub farmall ????? posted by bodid1998 on May 06, 2009 at 18:19:40:
The slightest bit of slop in the linkage between the gov and carb will cause problems. Sounds like either someone has tried a "fix" without instructions or you have bent/broken/stuck parts inside the gov.
Remove the governor and check to see if part #29 is bent or broke. or the weights are stuck.
Before you attempt to remove the gov, set the engine to #1 cylinder TDC. Remove the dist/mag and mark the gears so that you can get them lined back up upon reassembly.
