Re: Ledger plates
Posted by GordoSD on May 06, 2009 at 20:34:02 from (66.115.200.140):
In Reply to: Ledger plates posted by Dave H (MI) on May 06, 2009 at 13:10:15:
Sorry but that old mower is a POS. Upgrade to 100/1100 as soon as possible.
That said, you have serrated, worn ledger plates. PIA to replace. You must use smooth sections with them. Almost impossible to get holddowns with proper tension and spacing. When a mower is set up right you can pull the bar out with your hand fairly easily. 1 out of 50 won't pass this test.
Before you replace all the guards with smooth non plate surfaces, and all new sections with upper serrated sections , and most likely a new bar, your would be better off with IH/Rouse newer model balanced head mower. Don't throw good money after bad on this deal.
