Posted by screwstick on May 06, 2009 at 23:27:52 from (75.89.26.231):
In Reply to: cub farmall ????? posted by bodid1998 on May 06, 2009 at 18:19:40:
Solid. That (#6) is a key that will wear and get some play in it. Get all the play out of it that you can. Should be able to pull it straight out towards the carb after you remove the two bolts from part #5.
#8 will pivot inside the housing #20, with part #29 working against the shaft thrust bearing (#23) on one side and spring (#18) on the other.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
