Re: 2 H farmalls lots of differences,,
Posted by Owen Aaland on May 07, 2009 at 05:04:58 from (65.165.246.54):
In Reply to: 2 H farmalls lots of differences,, posted by Jim in Michigan on May 04, 2009 at 14:06:49:
Besides the PTO and lower transmission shaft and cast iron shift knob, you will probably find different radiators and caps, different front hood to accommodate the different radiator, different front hood mounting bolts. Frame rails are different. Early Hs used rubber front engine mounts with a closer bolt spacing in the rails. Belt pulley operating lever and rod were changed. Early rear housings had a hump on each side running forward from the brake pedal shaft. Brake drums were keyed to the bull pinions rather than splined like later models.
Other differences between our '40 and '43 that may not have been normal were that the '40 has a plastic covered steering wheel while the '43 had a hard rubber type coating. The '40 may have been changed in 1951 when my dad bought it. The '43 also had a plate on the side of the engine covering a hole where a fuel pump could be installed. This was probably a war time abnormality.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
