Posted by charles todd on May 07, 2009 at 07:34:25 from (205.242.95.130):
In Reply to: Hyd Hose posted by GordoSD on May 06, 2009 at 20:03:58:
Hal, that looks like a "government job"! If not, you bought some high dollar hose... I have access at work to about any hose and fitting I'll ever need.
GordoSD, I am trying to picture your application and I am thinking a 3" bore cylinder is OVERKILL! Not that there is a problem with that. My FEL has 2 1/2" bore cylinders and at 1800 psi it claims 3380 lbs force at the front pins. I am using 8-AN (1/2") from the valve then it splits to 6-AN (3/8") to each cylinder. We use 8-AN on about everything, it will take all the flow of a standard tractor w/o an issue. If you can, use JIC fittings. Like Hal said, use NPT to JIC adapters on the couplings and cylinders then JIC on the hose ends. It makes service work easier.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
