wd 9
Posted by greyfoxxca on May 07, 2009 at 07:41:34 from (137.186.183.161):
Hi Folks
I have acquired an old wd9. The engine is locked and I was trying to gain access to the cylinders through the spark plugs. As the valves from the spark plug area seems to be closed I tried moving the lever for the fuel switch over. It does not move also. When sitting in the seat the lever is in the forward position. Is this the diesel selection?
I will next just pull the injectors to get access to the engine for a look. What is the best way to unlock old motors.
someone said rislone , has anyone else had luck with this.
If I cannot unlock the engine it may become a lawn ornament.
george
  • Re: wd 9 Ron in Nebr 14:02:31 05/08/09 (0)
  • Re: wd 9 rustred 08:11:04 05/07/09 (0)
