Re: super c igniton timming
Posted by El Toro on May 07, 2009 at 16:35:16 from (205.188.116.73):
In Reply to: super c igniton timming posted by Jerry Edd Allen on May 07, 2009 at 11:23:42:
You could use a timing light. Are you sure the distributor isn't a tooth or so off. You could bring No1 piston near the radiator to TDC on the compression stroke and then remove the cap and see where your rotor is pointing. Should be at the No1 plug tower. Hal
