Re: Super C engine froze
Posted by gene bender on May 08, 2009 at 03:56:48 from (67.55.227.59):
In Reply to: Super C engine froze posted by Tom52 on May 08, 2009 at 03:05:36:
Remove the head to check the cycl walls they must be rusty and are probably junk. The engine is a wet sleeve engine so you can pull the sleeve and piston all at once. Replace with new and grind the crank get the head serviced and you will have a new engine. Theres a good reason its stuck and no magic fluid will make good cycl walls. Cant you see the walls thru the spark plug holes that will give a great indication of why its stuck. Bite the bullet and do it rite.
