Re: Super C engine froze
Posted by El Toro on May 08, 2009 at 04:09:28 from (205.188.116.73):
In Reply to: Super C engine froze posted by Tom52 on May 08, 2009 at 03:05:36:
Pull the head and look at the sleeves to see how rusty they are. You probably need to drop the oil pan and remove one of the rod caps and use a piece of 2X2 oak and a big hammer and drive the piston out. The sleeves are not pressed in and may come with the piston. Use a torch then to heat the sleeve to remove the piston. You probably need to tear the engine down completely
and have the crankshaft measured for wear and have the block cleaned. New sleeve kits are available and your local machine shop can supply the correct new bearings. Good time to look at the clutch too. It would be easier to work on the engine by splitting the tractor. I had to do this on a Farmall A back in 1975. Hal
