Must not be out of time or it wouldnt start good. Have you set the linkage going to the carb from the gov and is the input shaft good doing into the gov housing. There is a thrust bearing in the gov and maybe a new spring is needed. With a timing lite and the TDC marked on the flywheel you can see if the dist advances when throttle is advanced.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
