Re: 130 governer spring
Posted by Bob on May 08, 2009 at 05:02:26 from (69.178.228.68):
In Reply to: 130 governer spring posted by Kerry (N.S.) on May 08, 2009 at 04:19:50:
The governor ball thrust bearing CAN fall apart,but only if it is worn out anyhow.
The biggest deal will be timing, if the shaft is removed. Easiest way is to put the engine @ TDC, then note EXACTLY where the drive is at.
