Re: IHC Titan 10-20
Posted by Bobcat on May 08, 2009 at 07:14:03 from (69.66.139.140):
In Reply to: IHC Titan 10-20 posted by joemims on May 07, 2009 at 18:46:18:
Joe, If your block does not have a tag on the front above the fuel tank then look at the block on the flywheel side right behind where the crankshaft comes out. There will be a small pad with the numbers stamped on it! Kind of hard to see! There were a few made with out the tag on the block Mine Included. Some claim it is stamped on the end of the crankshaft but I have not found that.
If you don't find any numbers the details of your tractror- Mixer or carb.size of cooling tank. fender style, platform style,fuel tank return location,diameter of clutch pulley, will help in getting a close estimate!
